Philips  43BDL3510Q 43 INCH INCH UHD 4K 18/7 Display
Quicklinx: GL8GWS00 Mfr#: 43BDL3510Q/00
Inform and enthrall with a Philips Q-Line Professional Ultra HD Display. This reliable solution can be up and running as quickly as you need.
  • Operate, monitor and maintain with CMND and Control
    Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
  • FailOver ensures that content is always playing
    From waiting room to meeting room, never show a blank screen. FailOver lets your Philips Professional Display switch automatically between primary and secondary inputs, ensuring that content keeps playing even if the primary source goes down. Simply set a list of alternative inputs to be sure your business is always on.
  • Schedule what you want, when you want with SmartPlayer
    Turn your USB into a true cost-effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on-screen menu, and enjoy your own playlists anytime, anywhere.
  • Integrated media player - easily schedule USB content
    Easily schedule content to play from USB. Your Philips Professional Display will wake from standby to play the content you want, and then return to standby once playback has finished.
Philips 43BDL3510Q Q-Line - 43" Class (42.5" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/394484
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI
ADS
LCD Backlight Technology
Direct LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management, FailOver
Picture Enhancements
Motion Compensation, dynamic contrast enhancement, 3D Combfilter
Speaker System
2 speakers
USB
2 ports
Remote control
Voltage
Energy Class
Class G
150 Watt
Power Consumption (On mode)
100 W
Power Consumption Stand by
0.5 Watt
97.3 cm x 6.35 cm x 56.12 cm
11.3 kg
3-year warranty
Energy Class
Class G
150 Watt
100 W
100 kWh/1000h
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Series
Q-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI
Modes
Portrait mode, landscape mode
Dimensions
Without stand
97.3 cm
6.35 cm
56.12 cm
11.3 kg
Display
LCD Display Technology
ADS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Direct LED
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Commercial Features
Operation Hours / Days
18 / 7
3D MA deinterlacing
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 720, 720 x 400, 1152 x 870, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
WMV, H.264, MPEG
Supported Audio Formats
WMA, AAC, HE-AAC
Supported Pictures Formats
BMP, PNG, JPEG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Battery Included
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DVI-I input , 2 x HDMI , 2 x USB 2.0 , Audio line-in , Audio line-out , RS-232C input/output , Infrared input/output , Remote control
RS232 cable , IR sensor cable - 1.8 m
FCC Class A certified, VCCI, BSMI, CB, ETL, EPA, CU
Power supply
Input Voltage
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80% (non-condensing)
