Peerless-AV Wall Support For Dual Pole (Black)
Quicklinx: CM8YWS00 Mfr#: MOD-WP2
£64.46 ex VAT
£77.35 inc VAT
Peerless-AV's Modular Mount series features a full range of products to fulfill multiple requirements with a limited number of components. The universality of the components allows you to configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular Mount series was developed with the professional AV installer in mind with a 2" (50 mm) diameter support pole that can be easily cut to length on the job site making it ideal for projects as well as for upgrading existing installations. The MOD-WP2 makes wall mounting possible for floor to wall display placement applications.
Peerless Modular Series MOD-WP2 mounting component - for flat panel - black powder coat
Mounting component
Mounting Components
Wall plate, concrete anchor, dual pole clamp
25.4 cm x 17.6 cm x 11.5 cm
Adjustable Depth
9.5-14 cm
1.59 kg
Recommended Use
Flat panel
Recommended Display Size
46"-90"
Max Load Weight
192 kg
Black powder coat
5-year warranty
25.4 cm
17.6 cm
11.5 cm
Adjustable Depth
9.5-14 cm
1.59 kg
Black powder coat
AV Furniture
Mounting component
Mounting Components
Recommended Use
Flat panel
46"-90"
Max Load Weight
192 kg
Limited warranty - 5 years
Brand: Peerless-AV
