The DS508 tilt wall mount was designed to hold a PC with ease of installation in mind. The mount will disengage at the bottom, allowing the TV to tilt upward while removing the PC for service. The mount is both PLP and VESA compatible and is rated high enough to hold some of the largest screens. Tilt option are 0, 5 and 10 degrees.
Versatile mounting options
Designed to support a wide range of display sizes, the Peerless DS508 mounting kit offers on-wall mounting solutions for LCD displays up to 38 inches or 96.5 cm, ensuring a perfect fit for your viewing needs. -
Robust design
With a maximum load weight of 90 kg, this mounting kit is built to hold your LCD display securely, providing peace of mind that your technology investments are safely mounted. -
Comprehensive compatibility
The DS508 features multiple flat panel mount interfaces including 100 x 100 mm, 100 x 200 mm, 200 x 100 mm, and 200 x 200 mm, offering flexibility for mounting various LCD display and CPU configurations.
- Peerless DS508 mounting kit - for LCD display / CPU - black
- Product Type
- Mounting kit - on-wall mounted
- Mounting Components
- Wall bracket
- Adjustments
- Tilt
- Recommended Use
- LCD display / CPU
- Recommended Display Size
- 38"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm, 100 x 200 mm
- Max Load Weight
- 90 kg
- Black
- Black
AV Furniture
- Mounting kit
- Wall bracket
- Recommended Use
- LCD display / CPU
- Placing / Mounting
- On-wall mounted
- 38"
- Adjustments
- Tilt
- Max Load Weight
- 90 kg
