Peerless-AV Wall Mount 27-60" with PC Holder (100x378x337mm max)
Quicklinx: 9Z10WS00 Mfr#: DS508
£124.64 ex VAT
£149.56 inc VAT
The DS508 tilt wall mount was designed to hold a PC with ease of installation in mind. The mount will disengage at the bottom, allowing the TV to tilt upward while removing the PC for service. The mount is both PLP and VESA compatible and is rated high enough to hold some of the largest screens. Tilt option are 0, 5 and 10 degrees.
Peerless DS508 - mounting kit
Mounting kit - on-wall mounted
Mounting Components
Wall bracket
Adjustments
Tilt
Recommended Use
LCD display / CPU
Recommended Display Size
38"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm, 100 x 200 mm
Max Load Weight
90 kg
AV Furniture
Mounting kit
Mounting Components
Wall bracket
Recommended Use
LCD display / CPU
Placing / Mounting
On-wall mounted
38"
Adjustments
Tilt
Max Load Weight
90 kg
Brand: Peerless-AV
