Designed to wall mount smaller computers, the DS509 is a low-profile universal solution for digital signage applications. Its bottom disengaging design allows the screen to have a negative tilt that enables quick and easy computer maintenance without having to remove the screen. Engineered for strength, durability and easy installation this mount offers VESA compliance and is compatible with Peerless PLP adapter plate technology to accommodate any flat panel display.
Versatile mounting
Designed for flexibility, the Peerless Custom Slim Tilt Mount with PC Holder accommodates a wide range of display sizes from 25" to 60", ensuring a perfect fit for your LCD display and CPU setup. Its on-wall mounting design provides a sleek, space-saving solution for any room. -
Robust support
With the ability to support up to 91 kg, this mounting kit is built to hold your valuable equipment securely. The inclusion of multiple flat panel mount interfaces, including 100 x 100 mm, 100 x 200 mm, and 200 x 200 mm, offers compatibility with a variety of display models. -
Easy adjustments
The tilt feature allows for easy viewing angle adjustments, enhancing your viewing experience. Whether you're watching from the couch or presenting in a meeting, you can find the perfect angle for any situation.
- Peerless Custom Slim Tilt Mount with PC Holder DS509 mounting kit - for LCD display / CPU - black
- Product Type
- Mounting kit - on-wall mounted
- Mounting Components
- Wall bracket
- 7 cm x 26.1 cm x 46.4 cm
- Adjustments
- Tilt
- 6 kg
- Recommended Use
- LCD display / CPU
- Recommended Display Size
- 25" - 60"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 100 x 200 mm
- Max Load Weight
- 91 kg
- Black
- 7 cm
- 26.1 cm
- 46.4 cm
- 6 kg
- Black
AV Furniture
- Mounting kit
- Wall bracket
- Recommended Use
- LCD display / CPU
- Placing / Mounting
- On-wall mounted
- 25" - 60"
- Adjustments
- Tilt
- Max Load Weight
- 91 kg
