Peerless-AV Wall Mount 25-60" with PC Holder (51x378x229mm max)
Quicklinx: 9Z11WS00 Mfr#: DS509
£178.20 ex VAT
£213.84 inc VAT
Designed to wall mount smaller computers, the DS509 is a low-profile universal solution for digital signage applications. Its bottom disengaging design allows the screen to have a negative tilt that enables quick and easy computer maintenance without having to remove the screen. Engineered for strength, durability and easy installation this mount offers VESA compliance and is compatible with Peerless PLP adapter plate technology to accommodate any flat panel display.
  • Versatile mounting
    Designed for flexibility, the Peerless Custom Slim Tilt Mount with PC Holder accommodates a wide range of display sizes from 25" to 60", ensuring a perfect fit for your LCD display and CPU setup. Its on-wall mounting design provides a sleek, space-saving solution for any room.
  • Robust support
    With the ability to support up to 91 kg, this mounting kit is built to hold your valuable equipment securely. The inclusion of multiple flat panel mount interfaces, including 100 x 100 mm, 100 x 200 mm, and 200 x 200 mm, offers compatibility with a variety of display models.
  • Easy adjustments
    The tilt feature allows for easy viewing angle adjustments, enhancing your viewing experience. Whether you're watching from the couch or presenting in a meeting, you can find the perfect angle for any situation.
Peerless Custom Slim Tilt Mount with PC Holder DS509 mounting kit - for LCD display / CPU - black
Mounting kit - on-wall mounted
Mounting Components
Wall bracket
7 cm x 26.1 cm x 46.4 cm
Adjustments
Tilt
6 kg
Recommended Use
LCD display / CPU
Recommended Display Size
25" - 60"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 100 x 200 mm
Max Load Weight
91 kg
7 cm
26.1 cm
46.4 cm
6 kg
AV Furniture
Mounting kit
Mounting Components
Wall bracket
Recommended Use
LCD display / CPU
Placing / Mounting
On-wall mounted
25" - 60"
Adjustments
Tilt
Max Load Weight
91 kg
Brand: Peerless-AV
