Peerless-AV Video Wall Plate Spacer Kit for NEC X551UN Samsung UD55A
Quicklinx: C5W8WS00 Mfr#: DS-VWS040
£24.29 ex VAT
£29.14 inc VAT
Peerless spacer kits are designed to distance screens apart and create video walls in near seamless vertical, horizontal, and "tiled" matrix patterns.
  • Efficient installation
    Designed for ease of use, the Peerless-AV Spacer Kits facilitate a straightforward and efficient installation process, ensuring your AV equipment is mounted securely and precisely.
  • Versatile compatibility
    The mounting component feature of the Peerless-AV Spacer Kits offers broad compatibility with various AV furniture types, making it a flexible solution for different mounting needs.
Peerless-AV Spacer Kits DS-VWS040-P mounting component - for LCD display
Mounting component
Mounting Components
Wall mount spacer
Recommended Use
LCD display
Recommended Display Size
55"
5-year warranty
Hyundai D558FL; LG 55WV70; NEC MultiSync X551UN; Samsung UD55A
AV Furniture
Mounting component
Mounting Components
Wall mount spacer
Recommended Use
LCD display
55"
Portrait function
Limited warranty - 5 years
Hyundai D558FL , LG 55WV70 , NEC MultiSync X551UN , Samsung UD55A
Brand: Peerless-AV
