Peerless spacer kits are designed to distance screens apart and create video walls in near seamless vertical, horizontal, and "tiled" matrix patterns.
Efficient installation
Designed for ease of use, the Peerless-AV Spacer Kits facilitate a straightforward and efficient installation process, ensuring your AV equipment is mounted securely and precisely. -
Versatile compatibility
The mounting component feature of the Peerless-AV Spacer Kits offers broad compatibility with various AV furniture types, making it a flexible solution for different mounting needs.
- Peerless-AV Spacer Kits DS-VWS040-P mounting component - for LCD display
- Product Type
- Mounting component
- Mounting Components
- Wall mount spacer
- Recommended Use
- LCD display
- Recommended Display Size
- 55"
- 5-year warranty
- Designed For
- Hyundai D558FL; LG 55WV70; NEC MultiSync X551UN; Samsung UD55A
AV Furniture
- Wall mount spacer
- Recommended Use
- LCD display
- 55"
- Portrait function
- Limited warranty - 5 years
- Designed For
- Hyundai D558FL , LG 55WV70 , NEC MultiSync X551UN , Samsung UD55A
