Peerless-AV Video Wall Mount
Quicklinx: GRH5WS00 Mfr#: DS-VW775
£313.36 ex VAT
£376.03 inc VAT
Peerless-AV's Supreme Full Service Video Wall Mount raises the bar of excellence with an enhanced feature set centered on ease of install and display alignment. With the addition of tool-less lateral micro-adjustment, the Supreme offers 1.5" of fine tune adjustment on each of the X, Y and Z axis. Serviceability is easier than ever before with single hand pop-out release features on the top and bottom of the mount. Reusable spacers can be used for both portrait and landscape applications resulting in a faster install and lower cost. Enhanced cable management allows the cables to effortlessly travel in and out with the display, while the quick release accessory provides quick access in recessed applications without risking display damage or searching for hidden pull strings.
  • Effortless installation
    The Full Service Video Wall Mount from Peerless SmartMount makes setting up your video wall straightforward and efficient, thanks to its integrated cable management system. This feature ensures that cables are neatly organized, reducing clutter and simplifying access for maintenance and setup.
  • Versatile compatibility
    Designed to support a wide range of display sizes from 46" to 60", and compatible with flat panel mount interfaces of 200 x 200 mm, 300 x 300 mm, 400 x 300 mm, and 400 x 400 mm, this bracket is a flexible solution for various video wall configurations. Its flexibility makes it suitable for a multitude of commercial settings.
  • Robust design
    With the ability to hold up to 56.8 kg, the Full Service Video Wall Mount is built to support your video wall securely. This robust design ensures that your displays are safely mounted on the wall, providing peace of mind and a reliable foundation for your video wall project.
Peerless SmartMount Supreme Full Service Video Wall Mount bracket - for video wall - black
Bracket - wall-mountable
54 cm x 54 cm x 9.9 cm
11.4 kg
Recommended Use
Video wall
Recommended Display Size
46"-60"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 400 mm, 300 x 300 mm
Max Load Weight
56.8 kg
5-year warranty
54 cm
54 cm
9.9 cm
11.4 kg
AV Furniture
Bracket
Recommended Use
Video wall
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
46"-60"
Max Load Weight
56.8 kg
Limited warranty - 5 years
Brand: Peerless-AV
