Video wall displays no longer need to be limited to just walls and carts. With the Peerless-AV DS-VWT955-2X2, a video wall display can now be mounted to a ceiling. The tool-less micro adjustable design provides placement of four displays in a 2 x 2 configuration, neatly aligned on the same plane. The tilting adjustment options of 5, 10, 15 and 20 degrees means you can be assured of the perfect viewing angle for your application. It is ideal for department stores, entertainment venues or other large public areas. Compatible with Peerless-AV fixed length and adjustable length columns.
Versatile adjustments
With both tilt and adjustable height and width features, this mounting kit offers a flexible solution to meet various digital signage needs, ensuring optimal viewing angles and display configurations. -
Comprehensive compatibility
Designed to support a wide range of display sizes from 40" to 50" and equipped with a flat panel mount interface of 200 x 200 mm and 600 x 400 mm, this ceiling mount is versatile enough to accommodate most digital signage displays.
- Peerless Digital Signage Video Ceiling Mount DS-VWT955-2X2 mounting kit - black
- Product Type
- Mounting kit - ceiling mountable
- Mounting Components
- Ceiling mount
- Adjustments
- Tilt
- Recommended Display Size
- 40"-50"
- VESA Mounting Interface
- 200 x 200 mm, 600 x 400 mm
- Black
- Black
AV Furniture
- Mounting kit
- Ceiling mount
- Placing / Mounting
- Ceiling mountable
- 40"-50"
- Adjustments
- Tilt
- Adjustable height, adjustable width
