Thanks to technology advancements and the increased cost of travel, video conferencing is quickly becoming a commonplace in business around the globe. Peerless-AV's floor to wall solution makes implementation of video conferencing equipment that much easier. The mount's sleek design, compatible with any office decor, provides internal cable management and plenty of space for hardware storage. Two 2RU drop down racks, hidden behind the displays, are easily actuated and lowered below the display for easy service access. Displays in the 55" to 80" range can be set at the desired viewing angle with the camera shelf set accordingly.
- Peerless VCM580 - mounting kit - for video conferencing system
- Product Type
- Mounting kit
- Mounting Components
- Floor-to-wall mount solution
- 243.8 cm x 4.67 cm x 194.8 cm
- Adjustments
- Recommended Use
- Video conferencing system
- Recommended Display Size
- 55"-80"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Load Weight
- 152 kg
- Silver
- Package Content
- 2 x 2U rack storage units
- 5-year warranty
- 243.8 cm
- 4.67 cm
- 194.8 cm
- Silver
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Shelf Qty
- 1
- Cable Management
- Internal cable management
- 55"-80"
- Adjustments
- Max Load Weight
- 152 kg
- Adjustable Shelves Qty
- 1
- Finish
- Powder coated
- Limited warranty - 5 years
