Peerless-AV Universal Ultra Slim Articulating Wall Mount 37 - 65"
Quicklinx: BWY2WS00 Mfr#: SUA761PU
13 In Stock
£236.24 ex VAT
£283.48 inc VAT
The Peerless-AV DesignerSeries universal ultra slim articulating wall mount is designed exclusively for ultra-thin displays. The SUA761PU is built to hold medium to larger displays firmly in any position - landscape or portrait - while still offering an ultra-low profile. An innovative i-shaped adaptor plate makes it easy to access the back of the display, keeping hardware hidden, and features internal cable management, providing a clean, professional look that transitions smoothly from the wall to the display.
  • Versatile adjustments
    With leveling, roll, and tilt adjustments, this mounting kit offers optimal viewing angles and easy customization to suit any room setup.
  • Seamless cable management
    The integrated cable management system keeps cables neatly organized and out of sight, ensuring a clean and clutter-free installation.
  • Broad compatibility
    Designed to support flat panels ranging from 37" to 65", this mount is compatible with a wide array of display sizes, making it a flexible solution for various home or office environments.
  • Robust design
    Capable of supporting up to 36 kg, this mounting kit is built to hold your flat panel securely, providing peace of mind and a stable viewing experience.
  • Full motion articulation
    Featuring a full range of motion with -90° to 90° rotation and -5° to 15° tilt, the articulating wall mount allows for effortless adjustment to achieve the perfect viewing angle.
Peerless-AV Designer Series SUA761PU mounting kit - for flat panel - black glossy finish
Mounting kit - wall-mountable
Mounting Components
Articulating wall mount
61.9 cm 43 cm
Adjustable Depth
4.7-63.1 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Roll, levelling, tilt
Recommended Use
Flat panel
Recommended Display Size
37"-65"
VESA Mounting Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
36 kg
Black glossy finish
61.9 cm
43 cm
Adjustable Depth
4.7-63.1 cm
Black glossy finish
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
37"-65"
Tilt
-5° to 15°
Rotation
-90° to 90°
Adjustments
Max Load Weight
36 kg
Brand: Peerless-AV
