Peerless-AV Universal Tilt Wall Mount for 32" to 40" Displays
Quicklinx: 7MS8WS00 Mfr#: PT640
Type: Mounting kit
More than 50 In Stock
£54.21 ex VAT
£65.05 inc VAT
Ideally suited for medium/large LCD screens, the Paramount PT640 tilting mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Effortless adjustment
    The Peerless PARAMOUNT Universal Tilt Wall Mount offers seamless tilt adjustments, allowing for the perfect viewing angle of your LCD display without the need for tools.
  • Robust construction
    Crafted from fused epoxy, this mounting kit is designed for durability and long-lasting use, ensuring your display stays securely in place.
  • Easy installation
    With the Sorted-For-You fasteners and a tilt wall plate, the installation process is simplified, making it easy to securely mount your LCD display.
  • Versatile compatibility
    Designed to support LCD displays ranging from 32" to 40", this mount provides a versatile solution for a wide range of models.
Peerless PARAMOUNT Universal Tilt Wall Mount PT640 mounting kit - for LCD display - gloss black
Mounting kit
Mounting Components
Fasteners, tilt wall plate
48.9 cm x 6.4 cm x 34.9 cm
Adjustments
Tilt
3 kg
Recommended Use
LCD display
Recommended Display Size
32"-40"
Max Load Weight
45 kg
Material
Fused epoxy
Gloss black
5-year warranty
48.9 cm
6.4 cm
34.9 cm
3 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
32"-40"
Adjustments
Tilt
Max Load Weight
45 kg
Sorted-For-You
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
