Peerless-AV Universal Tilt Wall Mount For 10" to 24" Displays
Quicklinx: 7MVTWS00 Mfr#: PT630
Type: Mounting kit
£20.99 ex VAT
£25.18 inc VAT
Ideally suited for small (10-24") LCD screens, the Paramount PT630 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Versatile mounting
    Designed to accommodate LCD TVs from 10"-24", the Peerless PARAMOUNT Universal Tilt Wall Mount offers a flexible solution for your home entertainment setup. Its adjustable tilt feature ensures optimal viewing angles, enhancing your viewing experience.
  • Durable construction
    Crafted from high-quality steel, this mounting kit is built to last. The scratch-resistant finish keeps it looking new, ensuring your setup always appears sleek and professional.
  • Easy installation
    With both mounting and wall plates included, the installation process is streamlined, making it easy for you to securely attach your LCD TV to the wall. The compatibility with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm provides a versatile fit for a wide range of TVs.
Peerless PARAMOUNT Universal Tilt Wall Mount PT630 mounting kit - for LCD TV - gloss black
Mounting kit
Mounting Components
Wall plate, mounting plate
12.1 cm x 5.7 cm x 12.1 cm
Adjustments
Tilt
0.57 kg
Recommended Use
LCD TV
Recommended Display Size
10"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.2 kg
Material
Steel
Gloss black
5-year warranty
12.1 cm
5.7 cm
12.1 cm
0.57 kg
Material
Steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
10"-24"
Adjustments
Tilt
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
