Ideally suited for small (10-24") LCD screens, the Paramount PT630 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
Versatile mounting
Designed to accommodate LCD TVs from 10"-24", the Peerless PARAMOUNT Universal Tilt Wall Mount offers a flexible solution for your home entertainment setup. Its adjustable tilt feature ensures optimal viewing angles, enhancing your viewing experience. -
Durable construction
Crafted from high-quality steel, this mounting kit is built to last. The scratch-resistant finish keeps it looking new, ensuring your setup always appears sleek and professional. -
Easy installation
With both mounting and wall plates included, the installation process is streamlined, making it easy for you to securely attach your LCD TV to the wall. The compatibility with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm provides a versatile fit for a wide range of TVs.
- Peerless PARAMOUNT Universal Tilt Wall Mount PT630 mounting kit - for LCD TV - gloss black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, mounting plate
- 12.1 cm x 5.7 cm x 12.1 cm
- Adjustments
- Tilt
- 0.57 kg
- Recommended Use
- LCD TV
- Recommended Display Size
- 10"-24"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 36.2 kg
- Material
- Steel
- Gloss black
- 5-year warranty
- 12.1 cm
- 5.7 cm
- 12.1 cm
- 0.57 kg
- Material
- Steel
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- LCD TV
- 10"-24"
- Adjustments
- Tilt
- Max Load Weight
- 36.2 kg
- Scratch-resistant
- Limited warranty - 5 years
