Peerless-AV makes it simple to mount almost any tablet with the PTM200. With its width and height adjustable cradle, this versatile, universal tablet adapts to virtually any tablet, securing it tightly into place. Its 75 x 75 mm VESA pattern allows it to attach to any wall mount with a matching pattern, and its sleek design makes it just as stylish as it is functional.
Versatile mounting
The Peerless Universal Tablet Cradle offers adjustable height and width, ensuring a perfect fit for a variety of tablet sizes. This flexibility allows for a tailored user experience, accommodating personal or professional use with ease. -
Secure installation
Equipped with a robust wall mount component, this mounting kit provides a stable and secure base for your tablet. The design focuses on safety and reliability, ensuring your device stays in place, whether it's for interactive displays or static information sharing. -
Optimized compatibility
Designed with a flat panel mount interface of 75 x 75 mm, the cradle supports a wide range of tablets up to 2.27 kg. This feature ensures that your device, regardless of its brand or model, can be easily integrated into your workspace or living area.
- Peerless Universal Tablet Cradle PTM200 mounting kit - for tablet - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 4.2 cm
- Adjustable Width
- 17.6-29 cm
- Adjustable Height
- 11.4-21.5 cm
- 350 g
- Recommended Use
- Tablet
- VESA Mounting Interface
- 75 x 75 mm
- Max Load Weight
- 2.27 kg
- Black
- Designed For
- 100 Series Desktop Mount LCT100S; 420A Series Wall Mount LCW420A; 620AD Series Wall Mount LCW620AD
- 4.2 cm
- Adjustable Width
- 17.6-29 cm
- Adjustable Height
- 11.4-21.5 cm
- 350 g
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Tablet
- Placing / Mounting
- Wall-mountable
- 75 x 75 mm
- Max Load Weight
- 2.27 kg
- Adjustable height, adjustable width
- Designed For
- Peerless 100 Series Desktop Mount LCT100S , Peerless 420A Series Wall Mount LCW420A , Peerless 620AD Series Wall Mount LCW620AD
