Peerless-AV Universal Pivot Wall Mount For 22-40" Displays
Quicklinx: 7MWWWS00 Mfr#: PP740
Accessory Type: Mount
£53.99 ex VAT
£64.78 inc VAT
Ideally suited for medium LCD screens, the Paramount PP740 pivoting wall mount gives you a wide range of screen adjustment to obtain a better viewing angle. The PP740 allows you to tilt your screen forward or back, pan left or right and even extend your flat panel screen away from the wall.
  • Versatile mounting
    Designed for LCD TVs ranging from 22"-40", the Peerless PARAMOUNT Pivot Wall Mount offers a flexible viewing experience with its tilt and swivel design. This feature ensures optimal viewing angles and enhances your TV watching experience.
  • Durable construction
    Crafted from aluminum and steel, this mounting kit is not only lightweight but also exceptionally sturdy. Its scratch-resistant finish ensures the mount maintains its aesthetic appeal over time, making it a reliable choice for your home entertainment setup.
  • Easy compatibility
    With a variety of flat panel mount interfaces including 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm, the Peerless PARAMOUNT Pivot Wall Mount is designed to accommodate a wide range of LCD TVs, ensuring a perfect fit for your device.
Peerless PARAMOUNT Pivot Wall Mount PP740 mounting kit - Tilt & Swivel - for LCD TV - high-gloss black
Mounting kit (Tilt & Swivel)
Mounting Components
Wall arm, mounting adapter
23.6 cm
Adjustable Width
22.2-26 cm
Adjustable Depth
7.5-20.6 cm
1.7 kg
Recommended Use
LCD TV
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36.2 kg
Material
Steel, anodised aluminium
High-gloss black
5-year warranty
23.6 cm
Adjustable Width
22.2-26 cm
Adjustable Depth
7.5-20.6 cm
1.7 kg
Material
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
22"-40"
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Brand: Peerless-AV
