Peerless-AV Universal Outdoor Tilt Wall Mount
Quicklinx: 9TX3WS00 Mfr#: EPT650
Hurry, only 3 left in stock!
£180.18 ex VAT
£216.21 inc VAT
Peerless' outdoor universal wall mount provides a sure way to mount flat panels outdoors with its corrosion resistant E-Coat and stainless steel hardware that is resistant to corrosion when exposed to the elements. In addition to simple installation with its hook-and-hang design, this mount offers tilt functionality while keeping the flat panel screen a mere 2.58" from the wall. Tamper-resistant hardware deters theft, offering a peace-of-mind with every installation.
  • Easy screen centering
    8" of horizontal adjustment for ideal screen position.
  • Simple set-up
    Hook-and-hang design helps attach enclosure to mount and hold the weight load while fine-tuning adjustments.
  • Viewing angle flexibility
    Incremental tilt settings enable the best viewing angle.
  • Easy access
    Open wall plate design provides easy access and pass through of cables to internal and external power and content sources.
Peerless Universal EPT650 mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall plate
78.1 cm x 6.6 cm x 47 cm
Adjustments
Tilt
4 kg
Recommended Use
Flat panel
Recommended Display Size
32"-55"
VESA Mounting Interface
600 x 400 mm
Max Mounting Pattern Size
738 x 449 mm
Max Load Weight
79 kg
Material
Stainless steel
5-year warranty
78.1 cm
6.6 cm
47 cm
4 kg
Material
Stainless steel
AV Furniture
Mounting kit
Mounting Components
Wall plate
Recommended Use
Flat panel
Environment
Indoor, outdoor
600 x 400 mm
738 x 449 mm
Cable Management
Integrated cable management
32"-55"
Adjustments
Tilt
Max Load Weight
79 kg
Horizontal shift
Limited warranty - 5 years
Brand: Peerless-AV
