Peerless' outdoor universal wall mount provides a sure way to mount flat panels outdoors with its corrosion resistant E-Coat and stainless steel hardware that is resistant to corrosion when exposed to the elements. In addition to simple installation with its hook-and-hang design, this mount offers tilt functionality while keeping the flat panel screen a mere 2.58" from the wall. Tamper-resistant hardware deters theft, offering a peace-of-mind with every installation.
Easy screen centering
8" of horizontal adjustment for ideal screen position. -
Simple set-up
Hook-and-hang design helps attach enclosure to mount and hold the weight load while fine-tuning adjustments. -
Viewing angle flexibility
Incremental tilt settings enable the best viewing angle. -
Easy access
Open wall plate design provides easy access and pass through of cables to internal and external power and content sources.
 - Peerless Universal EPT650 mounting kit - for flat panel - black
- Product Type
 - Mounting kit
- Mounting Components
 - Wall plate
 - 78.1 cm x 6.6 cm x 47 cm
- Adjustments
 - Tilt
 - 4 kg
- Recommended Use
 - Flat panel
- Recommended Display Size
 - 32"-55"
- VESA Mounting Interface
 - 600 x 400 mm
- Max Mounting Pattern Size
 - 738 x 449 mm
- Max Load Weight
 - 79 kg
- Material
 - Stainless steel
 - Black
 - 5-year warranty
 - 78.1 cm
 - 6.6 cm
 - 47 cm
 - 4 kg
- Material
 - Stainless steel
 - Black
AV Furniture
 - Mounting kit
 - Wall plate
- Recommended Use
 - Flat panel
- Environment
 - Indoor, outdoor
 - 600 x 400 mm
 - 738 x 449 mm
- Cable Management
 - Integrated cable management
 - 32"-55"
- Adjustments
 - Tilt
- Max Load Weight
 - 79 kg
 - Horizontal shift
 - Limited warranty - 5 years
