The SmartMount Universal Kiosk Stand's stylish appearance and sturdy construction make it perfect for diverse applications where aesthetics and safety are key. When paired with flat panel displays between 32"-75" it becomes an integral multimedia platform perfect for virtually any public venue. Space is provided under the display mount to house a media player and surge protector while the internal cable management system organizes and conceals cables, delivering a complete solution ideal for any application.
Versatile positioning
With a pan of 360° and a tilt of 30°, this Universal Kiosk Stand offers flexibility in display positioning, ensuring optimal viewing angles for all users. -
Broad compatibility
Designed to support LCD displays and digital players ranging from 32" to 75", or 81.3 to 190.5 cm, this stand accommodates a wide variety of screen sizes, making it a fit for virtually any installation. -
Robust support
Capable of holding devices weighing up to 68.3 kg, the stand is built with durability in mind, ensuring that even heavy displays can be securely mounted and showcased.
- Peerless-AV SmartMount Universal Kiosk Stand stand - for LCD display / digital player - black
- Product Type
- Stand
- 88.9 cm x 73.7 cm x 117.2 cm
- Tilt
- 30°
- Pan
- 360°
- 30.59 kg
- Recommended Use
- LCD display / digital player
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- Up to 600 x 400 mm, from 200 x 200 mm
- Max Load Weight
- 68.3 kg
- Black
- 88.9 cm
- 73.7 cm
- 117.2 cm
- 30.59 kg
- Black
AV Furniture
- Stand
- Recommended Use
- 32"-75"
- Tilt
- 30°
- Pan
- 360°
- Max Load Weight
- 68.3 kg
