The SmartMount Universal Kiosk Stand's stylish appearance and sturdy construction make it perfect for diverse applications where aesthetics and safety are key. When paired with flat panel displays between 32"-75" it becomes an integral multimedia platform perfect for virtually any public venue. Space is provided under the display mount to house a media player and surge protector while the internal cable management system organizes and conceals cables, delivering a complete solution ideal for any application.
                Versatile positioningWith a pan of 360° and a tilt of 30°, this Universal Kiosk Stand offers flexibility in display positioning, ensuring optimal viewing angles for all users.
                Broad compatibilityDesigned to support LCD displays and digital players ranging from 32" to 75", or 81.3 to 190.5 cm, this stand accommodates a wide variety of screen sizes, making it a fit for virtually any installation.
                Robust supportCapable of holding devices weighing up to 68.3 kg, the stand is built with durability in mind, ensuring that even heavy displays can be securely mounted and showcased.
- Peerless-AV SmartMount Universal Kiosk Stand stand - for LCD display / digital player - black
- Product Type
- Stand
- 88.9 cm x 73.7 cm x 117.2 cm
- Tilt
- 30°
- Pan
- 360°
- 30.59 kg
- Recommended Use
- LCD display / digital player
- Recommended Display Size
- 32"-75"
- VESA Mounting Interface
- Up to 600 x 400 mm, from 200 x 200 mm
- Max Load Weight
- 68.3 kg
- Black
- 88.9 cm
- 73.7 cm
- 117.2 cm
- 30.59 kg
- Black
AV Furniture
- Stand
- Recommended Use
- 32"-75"
- Tilt
- 30°
- Pan
- 360°
- Max Load Weight
- 68.3 kg
