Ideally suited for extra large LCD and plasma screens, the Paramount PF660 flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
Durable design
Crafted from cold-rolled steel, this mounting kit offers a scratch-resistant finish, ensuring longevity and maintaining its sleek look over time. -
Versatile compatibility
Designed to support flat panels ranging from 39" to 90", the Peerless PARAMOUNT Universal Flat Wall Mount accommodates a wide variety of screen sizes, making it an ideal choice for various display needs. -
Robust support
With the ability to hold up to 90.8 kg, this mounting kit provides a secure and stable platform for your flat panel, ensuring safety and peace of mind.
- Peerless PARAMOUNT Universal Flat Wall Mount PF660 mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, bracket adapter
- 78.1 cm x 4.3 cm x 45.7 cm
- 3.5 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 39"-90"
- Max Mounting Pattern Size
- 825 x 450 mm
- Max Load Weight
- 90.8 kg
- Material
- Cold-rolled steel
- Gloss black
- 5-year warranty
- 78.1 cm
- 4.3 cm
- 45.7 cm
- 3.5 kg
- Material
- Cold-rolled steel
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 825 x 450 mm
- 39"-90"
- Max Load Weight
- 90.8 kg
- Scratch-resistant
- Limited warranty - 5 years
