Easily install medium to large displays with this simple, intuitive mounting solution. Cables are easily managed behind the display with large access ports in the wall plate. Effortlessly achieve the desired display position with smooth sliding along the mount's horizontal wall plate rails.
- Peerless PARAMOUNT Universal Flat Wall Mount PF650 mounting kit - for flat panel - gloss black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, bracket adapter
- 80.8 cm x 4 cm x 45.7 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 39"-75"
- Max Mounting Pattern Size
- 742 x 405 mm
- Max Load Weight
- 68 kg
- Material
- Cold-rolled steel
- Gloss black
- 5-year warranty
- 80.8 cm
- 4 cm
- 45.7 cm
- Material
- Cold-rolled steel
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- 742 x 405 mm
- 39"-75"
- Max Load Weight
- 68 kg
- Scratch-resistant
- Limited warranty - 5 years
