Peerless-AV Universal Flat Wall Mount for 37" to 75" Displays
Quicklinx: 7B39WS00 Mfr#: PF650
Type: Mounting kit
More than 50 in stock
£34.59 ex VAT
£41.50 inc VAT
Easily install medium to large displays with this simple, intuitive mounting solution. Cables are easily managed behind the display with large access ports in the wall plate. Effortlessly achieve the desired display position with smooth sliding along the mount's horizontal wall plate rails.
Peerless PARAMOUNT Universal Flat Wall Mount PF650 - mounting kit
Mounting kit
Mounting Components
Wall plate, bracket adapter
80.8 cm x 4 cm x 45.7 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
39"-75"
Max Mounting Pattern Size
742 x 405 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
Gloss black
5-year warranty
80.8 cm
4 cm
45.7 cm
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD / plasma panel
742 x 405 mm
39"-75"
Max Load Weight
68 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
Price Range Ex VAT: 0 - 50
