Peerless-AV Universal Flat Wall Mount for 32" to 40" Displays
Quicklinx: 7TP6WS00 Mfr#: PF640
Type: Mounting kit
Hurry, only 1 left in stock!
£35.00 ex VAT
£42.00 inc VAT
Ideally suited for medium/large LCD screens, the Paramount PF640 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
  • Effortless installation
    The Peerless PARAMOUNT Universal Flat Wall Mount is designed with a Sorted-For-You feature, streamlining the setup process and ensuring a hassle-free installation. This innovative approach allows for quick and easy mounting, making it an ideal choice for both professionals and DIY enthusiasts.
  • Durable design
    Constructed from fused epoxy, this mounting kit offers exceptional durability and a scratch-resistant finish. Its robust design ensures your LCD display remains securely mounted, while the aesthetic appeal of the mount is maintained over time.
  • Versatile compatibility
    Accommodating a wide range of display sizes from 32" to 46" (81.3-116.8 cm), the Peerless PARAMOUNT Universal Flat Wall Mount is designed to support LCD displays up to 45 kg. This versatility makes it a perfect fit for a variety of settings, from home entertainment systems to professional presentations.
Peerless PARAMOUNT Universal Flat Wall Mount PF640 mounting kit - for LCD display - gloss black
Mounting kit
Mounting Components
Wall plate, bracket adapter
48.9 cm x 3 cm x 34.9 cm
2 kg
Recommended Use
LCD display
Recommended Display Size
32"-46"
VESA Mounting Interface
400 x 300 mm
Max Load Weight
45 kg
Material
Fused epoxy
Gloss black
5-year warranty
48.9 cm
3 cm
34.9 cm
2 kg
Material
Fused epoxy
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
400 x 300 mm
32"-46"
Max Load Weight
45 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
