Peerless-AV Universal Flat Wall Mount For 10" to 24" Displays
Quicklinx: 7MVPWS00 Mfr#: PF630
Type: Mounting kit
13 In Stock
£16.41 ex VAT
£19.69 inc VAT
Ideally suited for small (10-2") LCD screens, the Paramount PF630 flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 17mm away from the wall.
  • Versatile compatibility
    Designed to support LCD TVs ranging from 10" to 24", this mounting kit accommodates a variety of screen sizes, ensuring a perfect fit for your display needs.
  • Robust design
    With a maximum load weight of 36.2 kg, this mount provides a secure and stable foundation for your television, offering peace of mind and enhanced safety.
  • Easy installation
    Featuring a straightforward mounting process with a mounting adapter and wall plate included, setting up your TV becomes a hassle-free experience.
  • Scratch-resistant finish
    The scratch-resistant coating ensures that the mount maintains its aesthetic appeal, protecting it from wear and tear over time.
Peerless PARAMOUNT Universal Flat Wall Mount PF630 mounting kit - for LCD TV - gloss black
Mounting kit
Mounting Components
Wall plate, mounting adapter
14.2 cm x 1.7 cm x 12.7 cm
0.58 kg
Recommended Use
LCD TV
Recommended Display Size
10"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.2 kg
Gloss black
5-year warranty
14.2 cm
1.7 cm
12.7 cm
0.58 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
10"-24"
Max Load Weight
36.2 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
