Peerless-AV Universal Ceiling Mount for 32-75" Displays
Quicklinx: 9Z1WWS00 Mfr#: PLCM-UNL-CP
£267.84 ex VAT
£321.40 inc VAT
The Straight Column Ceiling Mount offers a 33" straight column from the ceiling attachment point to the center of the flat panel screen. The Straight Column Ceiling mount is ideal for sports facilities, airports, lobbies or retail environments. It delivers 20° of adjustable tilt and 360° of swivel. This mount ships complete with 2.5' fixed length extension column and theft resistant security fasteners.
  • Versatile placement
    Designed for ceiling-mountable placement, this Peerless Solid-Point Flat Panel Straight Column Mount offers a secure and elevated position for flat panels ranging from 32" to 90", ensuring an optimal viewing experience in various settings.
  • Secure installation
    Equipped with Penta-pin security screws and a comprehensive mounting kit, including an adapter plate, ceiling arm box, ceiling plate, retaining collar, support pipe, and tilt bracket, this mount provides a robust and secure installation for your valuable display.
  • Adjustable viewing
    Featuring tilt adjustments, this mounting kit allows for the perfect viewing angle, enhancing the viewing experience by accommodating different viewer positions and reducing glare.
Peerless Solid-Point Flat Panel Straight Column Mount PLCM-UNL-CP mounting kit - for flat panel - black
Mounting kit - ceiling mountable
Mounting Components
Ceiling plate, tilt bracket, support pipe, adapter plate, ceiling arm box, retaining collar
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-90"
Max Load Weight
90.7 kg
5-year warranty
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
32"-90"
Adjustments
Tilt
Max Load Weight
90.7 kg
Limited warranty - 5 years
Brand: Peerless-AV
