It's easy to get the best viewing position when you can effortlessly pull out the display from the wall, position it in almost any direction, even turn it around corners and then smoothly return it to the wall when finished. Level the display at any time, even after installation, for that picture perfect end result. Never worry about cables and cords getting in the way; cable management delivers a clean clutter-free look to any installation.
Versatile viewing
With tilt and swivel design, the Peerless PARAMOUNT Articulating Wall Mount allows for optimal viewing angles, ranging from -5° to 15° tilt and -90° to 90° swivel adjustments, ensuring the perfect view from any position. -
Easy installation
The hook-and-loop strap system simplifies the installation process, allowing for a straightforward setup that saves time and hassle. Integrated cable management keeps cables neatly organized, promoting a clean and clutter-free environment. -
Durable design
Crafted with scratch-resistant materials, this mounting kit is designed to withstand the rigors of daily use while maintaining its aesthetic appeal. The robust construction supports flat panels up to 36 kg, ensuring a secure and stable display of your device.
- Peerless PARAMOUNT Articulating Wall Mount PA740 mounting kit - Tilt & Swivel - for flat panel - gloss black
- Product Type
- Mounting kit (Tilt & Swivel) - wall-mountable
- Mounting Components
- Articulating arm, adapter plate, hook bracket
- 23.9 cm 22.2 cm
- Adjustable Depth
- 7.1-37.9 cm
- Tilt
- -5° to 15°
- Rotation
- -90° to 90°
- 2.04 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 22"-40"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 36 kg
- Gloss black
- 23.9 cm
- 22.2 cm
- Adjustable Depth
- 7.1-37.9 cm
- 2.04 kg
- Gloss black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- Cable Management
- Integrated cable management
- 22"-40"
- Tilt
- -5° to 15°
- Rotation
- -90° to 90°
- Max Load Weight
- 36 kg
- Scratch-resistant, swivel adjustment, Hook-and-Hang
