Peerless-AV Universal Articulating Wall Mount For 22" to 40" Displays
Quicklinx: 7MWZWS00 Mfr#: PA740
Type: Mounting kit
10 In Stock
£68.44 ex VAT
£82.12 inc VAT
It's easy to get the best viewing position when you can effortlessly pull out the display from the wall, position it in almost any direction, even turn it around corners and then smoothly return it to the wall when finished. Level the display at any time, even after installation, for that picture perfect end result. Never worry about cables and cords getting in the way; cable management delivers a clean clutter-free look to any installation.
  • Versatile viewing
    With tilt and swivel design, the Peerless PARAMOUNT Articulating Wall Mount allows for optimal viewing angles, ranging from -5° to 15° tilt and -90° to 90° swivel adjustments, ensuring the perfect view from any position.
  • Easy installation
    The hook-and-loop strap system simplifies the installation process, allowing for a straightforward setup that saves time and hassle. Integrated cable management keeps cables neatly organized, promoting a clean and clutter-free environment.
  • Durable design
    Crafted with scratch-resistant materials, this mounting kit is designed to withstand the rigors of daily use while maintaining its aesthetic appeal. The robust construction supports flat panels up to 36 kg, ensuring a secure and stable display of your device.
Peerless PARAMOUNT Articulating Wall Mount PA740 mounting kit - Tilt & Swivel - for flat panel - gloss black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, adapter plate, hook bracket
23.9 cm 22.2 cm
Adjustable Depth
7.1-37.9 cm
Tilt
-5° to 15°
Rotation
-90° to 90°
2.04 kg
Recommended Use
Flat panel
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Gloss black
23.9 cm
22.2 cm
Adjustable Depth
7.1-37.9 cm
2.04 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Cable Management
22"-40"
Tilt
-5° to 15°
Rotation
-90° to 90°
Max Load Weight
36 kg
Scratch-resistant, swivel adjustment, Hook-and-Hang
Type: Mounting kit
Brand: Peerless-AV
