Peerless-AV Universal Articulating Wall Mount For 10"-29" Displays
Quicklinx: 7MWXWS00 Mfr#: PA730
£44.06 ex VAT
£52.87 inc VAT
The Paramount™ series wall mounts provide versatile and multi-functional features. With PA730, extend the display up to 14.85" (377mm) or fully-retract it to just 2.73" (69mm) from the wall for for the perfect viewing angle. The Hook-and-Hang™ system offers easy, one-person installation of the display. One-Touch™ tilt technology offers ±15° vertical tilt movement for the ideal viewing angle. Integrated cable management protects, contains and conceals cables for a clean installation.
  • Extends 14.85" (377mm) from the wall
  • Retracts to 2.73" (69mm) to save space
  • One-Touch tilt mechanism offers ±15° of tilt angle adjustment
  • ±5° of roll for post installation display leveling
  • ±90° of pivot
  • VESA® 75 and 100mm compliant
  • Design is UL listed and tested to four times stated load capacity
  • Versatile placement
    Designed for flexibility, the Peerless Universal Full-Motion Plus Wall Mount allows for easy tilt and swivel adjustments, ensuring the perfect viewing angle for every use.
  • Durable construction
    Crafted from aluminum and steel, this mounting kit is not only scratch-resistant but also built to support LCD TVs weighing up to 11.3 kg, combining strength with longevity.
  • Universal compatibility
    With mounting interfaces of 100 x 100 mm and 75 x 75 mm, this wall mount is compatible with a wide range of display sizes from 10"-29", making it a versatile choice for various LCD TV models.
Peerless Universal Full-Motion Plus Wall Mount PA730 mounting kit - Tilt & Swivel - for LCD TV - high-gloss black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, mounting adapter
14 cm
Adjustable Width
11.9-22.8 cm
Adjustable Depth
3.1-36.7 cm
Adjustments
Tilt
1.5 kg
Recommended Use
LCD TV
Recommended Display Size
10"-29"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.3 kg
Material
Steel, anodised aluminium
High-gloss black
5-year warranty
Casio EV-1000
14 cm
Adjustable Width
11.9-22.8 cm
Adjustable Depth
3.1-36.7 cm
1.5 kg
Material
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
LCD TV
Placing / Mounting
Wall-mountable
10"-29"
Adjustments
Tilt
Max Load Weight
11.3 kg
Scratch-resistant, swivel adjustment
Limited warranty - 5 years
Casio EV-1000
Brand: Peerless-AV
