The DS-VW650 ultra thin video wall is the ultimate sleek profile experience in video wall technology. A lightweight wall plate coupled with easy attachment rails are quickly installed to bring beauty and simplicity to the ultra thin video wall application. A sturdy locking rail attaches to the top for installation safety and security. This modular system creates an infinite configuration.
- Peerless Ultra Thin Flat Video Wall Mount DS-VW650 mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall plate, wall mount, mounting rails
- 88.9 cm x 1.8 cm x 51.3 cm
- 6.1 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-50"
- VESA Mounting Interface
- 200 x 200 mm, 600 x 400 mm
- Max Load Weight
- 34 kg
- Material
- Fused epoxy
- Black
- 5-year warranty
- 88.9 cm
- 1.8 cm
- 51.3 cm
- 6.1 kg
- Material
- Fused epoxy
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 40"-50"
- Max Load Weight
- 34 kg
- Scratch-resistant
- Limited warranty - 5 years
