Peerless-AV Ultra-Slim Universal Flat Wall Mount
Quicklinx: 9RKZWS00 Mfr#: SUF641
Hurry, only 1 left in stock!
£52.74 ex VAT
£63.28 inc VAT
The SUF641 brings flat panel displays closer to the wall than any other product in the industry. This near-invisible mount is the beauty that supports the modern style of the latest ultra-thin flat panel displays while the locking arm ensures a secure installation. This unmatched solution delivers space-saving, ultra-sleek looks and brings the display closer to the wall than any other mount in the world.
  • Slim design
    The Peerless Universal Ultra Slim Flat Wall Mount is designed with a fixed arm and wall plate that ensure a sleek and unobtrusive look, making it a suitable choice for modern homes and offices.
  • Versatile compatibility
    Supporting LCD displays ranging from 24" to 50", this mounting kit offers a versatile solution for a wide array of screen sizes, ensuring a suitable fit for your specific display needs.
  • Robust construction
    Built to hold a maximum load weight of 68 kg, the SUF641 model provides a secure and stable foundation for your LCD display, giving you peace of mind about the safety of your mounted equipment.
Peerless Universal Ultra Slim Flat Wall Mount SUF641 mounting kit - for LCD display - gloss black
Mounting kit
Mounting Components
Wall plate, fixed arm
51 cm x 0.5 cm x 14 cm
1.2 kg
Recommended Use
LCD display
Recommended Display Size
24" - 50"
Max Load Weight
68 kg
Gloss black
51 cm
0.5 cm
14 cm
1.2 kg
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
24" - 50"
Max Load Weight
68 kg
Brand: Peerless-AV
