Peerless-AV Ultra-Slim Universal Flat Wall Mount for 37-65" Displays
Quicklinx: 9YZ1WS00 Mfr#: SUF660P/BK
Hurry, only 1 left in stock!
£103.51 ex VAT
£124.21 inc VAT
Ultra Slim is the world's thinnest flat to wall mounting solution at less that 0.84cm - yes that's only 8.4mm! - making it almost invisible once installed. Designed for the next generation of super slim LCD panels this product is a step ahead of anything else available in the market. Own the most discrete wall mount ever developed with the Ultra Slim range from Peerless.
  • Robust design
    Crafted from cold-rolled steel, this mounting kit offers a durable solution for securing flat panels, ensuring longevity and reliability.
  • Versatile compatibility
    Designed to accommodate flat panels ranging from 40"-80", this ultra-thin flat wall mount provides a perfect fit for a wide array of display sizes, making it an ideal choice for various settings.
  • Sleek aesthetics
    The scratch-resistant feature of the Peerless Slimline Universal Ultra-Thin Flat Wall Mount ensures that it maintains its sleek, professional appearance, blending seamlessly with any decor.
Peerless Slimline Universal Ultra-Thin Flat Wall Mount SUF660P mounting kit - for flat panel - high-gloss black
Mounting kit
Mounting Components
Wall plate, bracket adapter
90 cm x 1 cm x 55.1 cm
2.6 kg
Recommended Use
Flat panel
Recommended Display Size
40"-80"
Max Mounting Pattern Size
825 x 449 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
High-gloss black
5-year warranty
90 cm
1 cm
55.1 cm
2.6 kg
Material
Cold-rolled steel
High-gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
825 x 449 mm
40"-80"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Brand: Peerless-AV
