One of the world's slimmest mounts, at only 19" (5 mm) thin, the SUF661 brings flat panel displays closer to the wall than most other products in the industry. This near-invisible mount is the beauty that supports the modern style of the latest ultra-thin flat panel displays while the locking arm ensures a secure installation. This unmatched solution delivers space-saving, ultra-sleek looks and brings the display ultra-close to the wall.
 - Peerless SUF661 Universal Ultra Slim Flat Wall Mount - mounting kit - for LCD display - gloss black
- Product Type
 - Mounting kit - wall-mountable
- Mounting Components
 - Fixed arm, wall mount
 - 93.3 cm x 0.5 cm x 14 cm
 - 2.1 kg
- Recommended Use
 - LCD display
- Recommended Display Size
 - 40"-80"
- Max Load Weight
 - 68 kg
 - Gloss black
 - 93.3 cm
 - 0.5 cm
 - 14 cm
 - 2.1 kg
 - Gloss black
AV Furniture
 - Mounting kit
- Recommended Use
 - LCD display
- Placing / Mounting
 - Wall-mountable
 - 40"-80"
- Max Load Weight
 - 68 kg
 - Scratch-resistant, lockable
