The SUF641 brings flat panel displays closer to the wall than any other product in the industry. This near-invisible mount is the beauty that supports the modern style of the latest ultra-thin flat panel displays while the locking arm ensures a secure installation. This unmatched solution delivers space-saving, ultra-sleek looks and brings the display closer to the wall than any other mount in the world.
                Slim designThe Peerless Universal Ultra Slim Flat Wall Mount is designed with a fixed arm and wall plate that ensure a sleek and unobtrusive look, making it a suitable choice for modern homes and offices.
                Versatile compatibilitySupporting LCD displays ranging from 24" to 50", this mounting kit offers a versatile solution for a wide array of screen sizes, ensuring a suitable fit for your specific display needs.
                Robust constructionBuilt to hold a maximum load weight of 68 kg, the SUF641 model provides a secure and stable foundation for your LCD display, giving you peace of mind about the safety of your mounted equipment.
- Peerless Universal Ultra Slim Flat Wall Mount SUF641 mounting kit - for LCD display - gloss black
- Product Type
- Mounting kit
- Mounting Components
- Wall plate, fixed arm
- 51 cm x 0.5 cm x 14 cm
- 1.2 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 24" - 50"
- Max Load Weight
- 68 kg
- Gloss black
- 51 cm
- 0.5 cm
- 14 cm
- 1.2 kg
- Gloss black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- 24" - 50"
- Max Load Weight
- 68 kg
