Perfect for conference rooms, lobbies or convention centers, the Flat Panel Display Stand provides a safe and secure solution for displaying digital content in public areas. Its versatile functionality and solid engineering enable you to display a single screen, two screens back to back or even four screens in either landscape or portrait orientations. The integrated security fasteners lock the screens in place, virtually eliminating theft. Additionally, internal cord management completely hides all wires and cables giving your display a clean, professional look while eliminating the possibility of accidental tripping on or snagging of cords.
Versatile placement
Designed for flexibility, this stand supports floor-standing placement, allowing you to position your displays in the most optimal location for visibility and engagement. -
Adjustable viewing
With the ability to adjust the height and switch between portrait and landscape orientations, this stand offers viewing customization for up to 4 LCD displays, ensuring an ideal viewing experience for any content. -
Broad compatibility
Catering to a wide range of display sizes from 32" to 60" and equipped with multiple flat panel mount interfaces (100 x 100 mm, 200 x 100 mm, 200 x 200 mm), this stand is designed to accommodate various display models with ease.
 - Peerless Flat Panel Display Stand FPZ-600 stand - for 4 LCD displays - black
- Product Type
 - Stand - floor-standing
 - 73.7 cm x 91.4 cm x 184 cm
 - 49.1 kg
- Recommended Use
 - 4 LCD displays
- Recommended Display Size
 - 32"-60"
- VESA Mounting Interface
 - 100 x 100 mm, 200 x 200 mm, 200 x 100 mm
 - Black
 - 5-year warranty
 - 73.7 cm
 - 91.4 cm
 - 184 cm
 - 49.1 kg
 - Black
AV Furniture
 - Stand
- Recommended Use
 - 4 LCD displays
- Placing / Mounting
 - Floor-standing
 - 32"-60"
 - Adjustable height, portrait to landscape movement
 - Limited warranty - 5 years
