Easily install large screens with this simple, intuitive mounting solution. Its simple hook-on installation combined with its toolless tilt angle adjustment enables LCD and plasma flat panel screens to be installed and adjusted quickly. Cables are easily managed behind the screen with large access ports in the wall plate.
Effortless installation
The integrated spirit level ensures a perfectly level mount, simplifying the installation process and saving time. -
Versatile compatibility
Designed to support flat panels ranging from 37" to 75", this mounting kit accommodates a wide variety of screen sizes, making it a flexible solution for different display needs. -
Robust design
With a maximum load weight of 10 kg and compatibility with mounting patterns up to 700 mm by 400 mm, this mount is built to hold your display securely in place.
- Peerless Tru Vue TRT650 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- 76 cm x 7.9 cm x 72.8 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-75"
- Max Mounting Pattern Size
- 700 x 400 mm
- Max Load Weight
- 10 kg
- Black powder coat
- 5-year warranty
- 76 cm
- 7.9 cm
- 72.8 cm
- Black powder coat
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 700 x 400 mm
- 37"-75"
- Max Load Weight
- 10 kg
- Integrated spirit level
- Limited warranty - 5 years
Peerless-AV TruVue Tilting Wall Mount for 37-75" LCD & Plasma Displays
