Easily install large screens with this simple, intuitive mounting solution. Its simple hook-on installation combined with its toolless tilt angle adjustment enables LCD and plasma flat panel screens to be installed and adjusted quickly. Cables are easily managed behind the screen with large access ports in the wall plate.
- Peerless Tru Vue TRT650 mounting kit - for flat panel - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- 76 cm x 7.9 cm x 72.8 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-75"
- Max Mounting Pattern Size
- 700 x 400 mm
- Max Load Weight
- 10 kg
- Black powder coat
- 5-year warranty
- 76 cm
- 7.9 cm
- 72.8 cm
- Black powder coat
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 700 x 400 mm
- 37"-75"
- Max Load Weight
- 10 kg
- Integrated spirit level
- Limited warranty - 5 years
