Peerless-AV TruVue Tilting Wall Mount for 37-75" LCD & Plasma Displays
Quicklinx: 97MSWS00 Mfr#: TRT650
Easily install large screens with this simple, intuitive mounting solution. Its simple hook-on installation combined with its toolless tilt angle adjustment enables LCD and plasma flat panel screens to be installed and adjusted quickly. Cables are easily managed behind the screen with large access ports in the wall plate.
  • Effortless installation
    The integrated spirit level ensures a perfectly level mount, simplifying the installation process and saving time.
  • Versatile compatibility
    Designed to support flat panels ranging from 37" to 75", this mounting kit accommodates a wide variety of screen sizes, making it a flexible solution for different display needs.
  • Robust design
    With a maximum load weight of 10 kg and compatibility with mounting patterns up to 700 mm by 400 mm, this mount is built to hold your display securely in place.
Peerless Tru Vue TRT650 mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
76 cm x 7.9 cm x 72.8 cm
Recommended Use
Flat panel
Recommended Display Size
37"-75"
Max Mounting Pattern Size
700 x 400 mm
Max Load Weight
10 kg
Black powder coat
5-year warranty
76 cm
7.9 cm
72.8 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
700 x 400 mm
37"-75"
Max Load Weight
10 kg
Integrated spirit level
Limited warranty - 5 years
