Peerless-AV TruVue Tilting Wall Mount for 22-40" Displays
Quicklinx: 97MQWS00 Mfr#: TRT632
This sleek, compact tilting wall mount delivers a big impact for mid-sized screens. Its simple hook-on installation combined with its adjustable tilt allows LCD screens to be installed and adjusted quickly. The tilt angle can be adjusted without the use of tools to give an enhanced viewing position.
  • Effortless installation
    The integrated spirit level in the Peerless Tru Vue TRT632 mounting kit ensures a perfectly level installation, making it easier than ever to set up your flat panel display securely on the wall.
  • Versatile compatibility
    With flat panel mount interfaces of 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm, this mounting kit is designed to accommodate a wide range of display sizes from 22"-40", offering a flexible solution for various flat panel models.
  • Robust design
    Capable of supporting flat panels weighing up to 25 kg, the Peerless Tru Vue TRT632 mounting kit combines durability with reliability, ensuring your display remains securely mounted.
Peerless Tru Vue TRT632 mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Tilt wall mount
22.6 cm x 4 cm x 22 cm
Recommended Use
Flat panel
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Black powder coat
5-year warranty
22.6 cm
4 cm
22 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Tilt wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
22"-40"
Max Load Weight
25 kg
Integrated spirit level
Limited warranty - 5 years
