This sleek, compact tilting wall mount delivers a big impact for small screens. Its simple hook-on installation combined with its adjustable tilt allows small LCD screens to be installed and adjusted quickly. The tilt angle can be adjusted without the use of tools to give an enhanced viewing position.
- Peerless Tru Vue TRT630 mounting kit - for LCD display - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Tilt wall mount
- 11.44 cm x 4 cm x 11.3 cm
- Recommended Use
- LCD display
- Recommended Display Size
- 10"-29"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 20 kg
- Black powder coat
- 5-year warranty
- 11.44 cm
- 4 cm
- 11.3 cm
- Black powder coat
AV Furniture
- Mounting kit
- Tilt wall mount
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 10"-29"
- Max Load Weight
- 20 kg
- Integrated spirit level
- Limited warranty - 5 years
