Peerless-AV TruVue Flat-to-Wall Mount for 37-75" LCD & Plasma Displays
Quicklinx: 97MKWS00 Mfr#: TRF650
The TruVue™ series wall mounts combine ease of installation with viewing flexibility. With TRF650, a low-profile design positions the TV just 30mm (1.18") from the wall. The Hook-and-Hang™ system offers easy, one-person installation of the TV. The adaptors hook onto the wall plate for a quick, simple and secure installation.
  • Low profile design positions the TV just 30mm (1.18") from the wall.
  • Universal mount fits TVs with mounting patterns up to VESA 700x400mm.
  • Simple Hook-and-Hang™ design for quick and easy installation.
  • Mounts to wood studs, concrete, cinder block or metal studs (metal stud accessory required).
  • Installation hardware included.
  • Tested to four times stated load capacity.
  • Effortless installation
    The integrated spirit level ensures a perfectly level installation, making the setup process quick and hassle-free for a flawless viewing experience.
  • Versatile compatibility
    Designed to support flat panels ranging from 37" to 75", this mounting kit accommodates a wide variety of screen sizes, ensuring a perfect fit for your display.
  • Robust design
    With a maximum load weight of 70 kg and compatibility with mounting patterns up to 700 mm by 400 mm, this mount provides a secure and stable foundation for your flat panel.
Peerless Tru Vue TRF650 mounting kit - for flat panel - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
72.6 cm x 3 cm x 43 cm
Recommended Use
Flat panel
Recommended Display Size
37"-75"
Max Mounting Pattern Size
700 x 400 mm
Max Load Weight
70 kg
Black powder coat
5-year warranty
72.6 cm
3 cm
43 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
700 x 400 mm
37"-75"
Max Load Weight
70 kg
Integrated spirit level
Limited warranty - 5 years
