Peerless-AV TruVue Flat-to-Wall-Mount for 22-40" Displays
Quicklinx: 97MHWS00 Mfr#: TRF632
13 In Stock
£14.36 ex VAT
£17.23 inc VAT
Locate mid-sized screens almost anywhere with this compact, versatile mount. Simply attach the wall plate to the wall, the adapter to the screen and hook it on to the wall plate - done. At only 14 mm (0.55") from the wall, this sleek mount is ideal for low-profile applications.
Peerless Tru Vue TRF632 mounting kit - for LCD display - black powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
Recommended Use
LCD display
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Black powder coat
5-year warranty
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
22"-40"
Max Load Weight
25 kg
Integrated spirit level
Limited warranty - 5 years
Brand: Peerless-AV
