Locate mid-sized screens almost anywhere with this compact, versatile mount. Simply attach the wall plate to the wall, the adapter to the screen and hook it on to the wall plate - done. At only 14 mm (0.55") from the wall, this sleek mount is ideal for low-profile applications.
- Peerless Tru Vue TRF632 mounting kit - for LCD display - black powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- Recommended Use
- LCD display
- Recommended Display Size
- 22"-40"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 25 kg
- Black powder coat
- 5-year warranty
- Black powder coat
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- LCD display
- Placing / Mounting
- Wall-mountable
- 22"-40"
- Max Load Weight
- 25 kg
- Integrated spirit level
- Limited warranty - 5 years
