Peerless-AV TruVue Black Pivot Wall Mount for 22-40" Displays
Quicklinx: 97MMWS00 Mfr#: TRP732
£40.04 ex VAT
£48.04 inc VAT
Smoothly pull out and position this mount to the ideal viewing angle then retract it tight to the wall to save space. Level the screen at any time, even after installation. With integrated cable management, cords and cables are never in the way - even when extending and retracting the display.
Peerless Tru Vue TRP732 mounting kit - for LCD display - black powder coat
Mounting kit - wall-mountable
Mounting Components
Pivot wall mount
29.9 cm
Adjustable Depth
9.8-25.8 cm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
15 kg
Black powder coat
5-year warranty
29.9 cm
Adjustable Depth
9.8-25.8 cm
Black powder coat
AV Furniture
Mounting kit
Mounting Components
Pivot wall mount
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
22"-40"
Adjustments
Tilt
Max Load Weight
15 kg
Swivel adjustment, integrated spirit level
Limited warranty - 5 years
Brand: Peerless-AV
