Peerless-AV Trolley For 32" - 75" Flat Panel, Height adjustable w/ Shelf
Quicklinx: BX1SWS00 Mfr#: SR575M
Hurry, only 2 left in stock!
£575.13 ex VAT
£690.15 inc VAT
The Full Featured SR575M Flat Panel TV Cart takes standard cart to the next level, making everyday usage more enjoyable. Height adjustment of the display and component shelf can be made without the removal of the TV by simply repositioning to your desired height and the fear of damaging doorways and walls has been averted by non-marring bumpers on each corner of the cart allowing even easier mobility from room to room while the UL certification ensures you that it can be done with safety in mind.
  • Effortless mobility
    Equipped with four swivel casters and locking casters, this cart allows for easy movement and stability when stationary, ensuring your flat panel can be transported safely and positioned with ease.
  • Versatile display compatibility
    With a flat panel mount interface ranging from 200 x 200 mm to 600 x 400 mm, this cart supports a wide range of display sizes from 32"-75", making it a flexible solution for various flat panel types.
  • Enhanced viewing experience
    Features such as adjustable height and swivel adjustment allow for optimal viewing angles and heights, ensuring a comfortable and customizable viewing experience for all users.
  • Robust design
    Constructed from high-quality aluminum and equipped with security hardware, this cart is designed for durability and to prevent theft, providing a secure solution for displaying your flat panel.
Peerless-AV SmartMount SR575M cart - for flat panel - black powder coat
Cart
90.8 cm x 76.2 cm x 1.736 m
Tilt
-5°
31.8 kg
Recommended Use
Flat panel
Recommended Display Size
32"-75"
VESA Mounting Interface
Up to 600 x 400 mm, from 200 x 200 mm
Max Load Weight
68.2 kg
Material
Aluminium
Black powder coat
Wheels Qty
4
5-year warranty
90.8 cm
76.2 cm
1.736 m
31.8 kg
Material
Aluminium
Black powder coat
AV Furniture
Cart
Recommended Use
Flat panel
Cable Management
Integrated cable management
32"-75"
Tilt
-5°
Max Load Weight
68.2 kg
Wheels Qty
4
Adjustable height, locking casters, swivel adjustment, swivel casters, security hardware, height-adjustable shelf
Limited warranty - 5 years
Brand: Peerless-AV
Price Range Ex VAT: £500 - £750
