The SR542-KAPP Cart has been designed to include features and aesthetics to match the capture board. Height adjustment, tilt, and internal cable management complimented by an attractive finish make this cart stand out from the rest. Designed for use with the Smart kapp™ 42" capture board, the trolley provides a robust and sturdy solution ideal for sharing information in all types of applications.
- Dedicated adaptor to fit SMART kapp™ 42" interactive whiteboard
- Pre-assembled base provides rigidity, stability and quick assembly
- Integrated cable management protects, contains and conceals cables for a clean, professional installation
- Maneuvers easily with swivel casters, two locking
- -5° tilt adjustment for optimal viewing position
- Security hardware prevents tampering and theft
- Lightweight aluminium construction
- Durable powder coated finish to withstand the wear & tear of everyday use
- Peerless-AV professional SR542-KAPP cart - for interactive whiteboard - white
- Product Type
- Cart - lockable
- 176.8 cm
- Tilt
- -5°
- 26.8 kg
- Recommended Use
- Interactive whiteboard
- Recommended Display Size
- 42"
- VESA Mounting Interface
- 400 x 400 mm
- Material
- Aluminium
- White
- 176.8 cm
- 26.8 kg
- Material
- Aluminium
- White
AV Furniture
- Cart
- Recommended Use
- 400 x 400 mm
- Lockable
- 42"
- Tilt
- -5°
