Peerless-AV Tempered Glass Shelf
Quicklinx: BX1WWS00 Mfr#: ACC-GS1
£172.90 ex VAT
£207.48 inc VAT
The SmartMount Tempered Glass Shelf is designed to attach to the newly redesigned SmartMount SR Flat Panel carts and SS Flat Panel stands. The shelf provides a secure yet sleek and contemporary surface for various AV equipment and accessories, creating the best viewing experience.
  • Robust construction
    Crafted from heavy gauge steel and tempered-glass, this mounting component ensures durability and stability for your audio/video components.
  • Versatile placement
    Designed for flexibility, it can be easily mounted on carts or stands, making it an ideal choice for various setups and environments.
Peerless-AV SmartMount ACC-GS1 mounting component - for audio/video components - black powder coat
Mounting component - cart mountable, stand mountable
Mounting Components
Shelf
50.8 cm x 44 cm x 9.1 cm
5.91 kg
Recommended Use
Audio/video components
Max Load Weight
4.55 kg
Material
Tempered glass, heavy gauge steel
Black powder coat
5-year warranty
50.8 cm
44 cm
9.1 cm
5.91 kg
Material
Black powder coat
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
Placing / Mounting
Cart mountable, stand mountable
Max Load Weight
4.55 kg
Limited warranty - 5 years
Brand: Peerless-AV
