The HP447 series flat-panel desktop swivel mount offers a secure, functional and sleek desktop surface mount for hospitality applications. It is designed to seamlessly connect to a variety of flat panel screen models while its deeper adapter plate allows for easy access to cable input connections. The built-in adapter plate is VESA 200 x 100 and 200 x 200 mm compliant and comes with security screws to deter tampering and theft. The mount provides more than just aesthetics and theft deterrence with its swivel range from 0º to 360º it delivers virtually any viewing angle within its diameter.
Effortless adjustability
With its adjustable height and swivel base features, the Peerless Desktop Swivel Mount offers flexibility, allowing users to find the perfect viewing angle for their LCD TV. -
Durable design
Crafted from fused epoxy and steel, this mounting kit is not only scratch-resistant but also equipped with security screws, ensuring a stable and secure mount for displays ranging from 32"-47". -
Seamless integration
The integrated cable management system ensures that cables are neatly organized and hidden from view, maintaining a clean and clutter-free setup.
- Peerless Desktop Swivel Mount HP447 mounting kit - for LCD TV - black powder coat
- Product Type
- Mounting kit
- Mounting Components
- Desktop swivel mount
- 23 cm x 15.2 cm x 55.6 cm
- 5 kg
- Recommended Use
- LCD TV
- Recommended Display Size
- 32"-47"
- VESA Mounting Interface
- 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 34 kg
- Material
- Steel, fused epoxy
- Black powder coat
- 5-year warranty
- 23 cm
- 15.2 cm
- 55.6 cm
- 5 kg
- Material
- Black powder coat
AV Furniture
- Mounting kit
- Recommended Use
- LCD TV
- Cable Management
- Integrated cable management
- 32"-47"
- Max Load Weight
- 34 kg
- Adjustable height, swivel base, scratch-resistant, security screws
- Limited warranty - 5 years
