Peerless-AV STP680 Tilt Wall Mount Port 46-90 158kg
Quicklinx: GRH9WS00 Mfr#: STP680
Hurry, only 1 left in stock!
£167.94 ex VAT
£201.52 inc VAT
Peerless-AV's SmartMount universal portrait tilt wall mount delivers an ultra-slim profile designed to hold large displays. Installation and maintenance are made easy with the STP680's robust feature set. Auto-latching adaptor rails automatically secure the display without the use of a tool. The mount's built-in kickstand holds the display safely from the wall during cable routing, while the open wall plate allows for increased electrical and cable management options. Horizontal and vertical display adjustment allow for quick fine-tuning of the mounted display.
Peerless-AV SmartMount STP680 bracket - for flat panel - semi-gloss black
Bracket - wall-mountable
55.9 cm 67.3 cm
Adjustable Depth
8.6-26.9 cm
Tilt
-5° to 15°
Adjustments
Levelling, tilt
6.3 kg
Recommended Use
Flat panel
Recommended Display Size
46"-90"
VESA Mounting Interface
650 x 400 mm
Max Mounting Pattern Size
650 x 494 mm
Max Load Weight
158.76 kg
Semi-gloss black
Package Content
Mounting hardware, allen wrench (4mm), security wrench
5-year warranty
55.9 cm
67.3 cm
Adjustable Depth
8.6-26.9 cm
6.3 kg
Semi-gloss black
Package Content
AV Furniture
Bracket
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
650 x 400 mm
650 x 494 mm
Cable Management
Integrated cable management
46"-90"
Tilt
-5° to 15°
Adjustments
Levelling, tilt
Max Load Weight
158.76 kg
Finish
Epoxy powder coated
Details
Portrait orientation
Dimensions & Weight Details
Dimensions
Wall plate - width: 55.9 cm height: 36.8 cm
Limited warranty - 5 years
Brand: Peerless-AV
